Nicki Miller Posted February 22, 2020 Posted February 22, 2020 Hi I have a Aritech CS350 alarm system installed and the keypad has turned yellow. Not a good luck with my new decor. I am trying to find out if their any other keypads that will be compatible with my system. Quote
james.wilson Posted February 22, 2020 Posted February 22, 2020 no they are all designed to work with only specific units Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted February 22, 2020 Posted February 22, 2020 19 minutes ago, james.wilson said: no they are all designed to work with only specific units Force the board into an older hkc pad ? Quote
sixwheeledbeast Posted February 22, 2020 Posted February 22, 2020 Your options come down to:- Carefully clean the keypad with some plastic cleaner (results may vary), I think they where an off white colour anyway from memory. Find a second hand one from the usual online places. Or the best option would be to upgrade your system, its no longer manufactured so support will be limited. Quote
Nova-Security Posted February 22, 2020 Posted February 22, 2020 (edited) 1 hour ago, Logan said: Good old aritech annoying how you couldn't use "0" in the code but people still tried and then the panel required defaulting Panel never required defaulting for that, just wouldn't allow a '0' in the code. Still by far one of the best panels ever the CD range 1 hour ago, sixwheeledbeast said: I think they where an off white colour anyway from memory. QFA they was never white. Edited February 22, 2020 by Nova-Security Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
