22 minutes ago, Eugene's DIY Den said:
Ok, so setting spit entry time to zero solved the problem. Now there's no delay between internal sounder and external bell activating when the entry door is opened and code isn't entered before the entry delay times out. However I still have an issue with alarmed internal doors and PIRs not activating the alarm if the entry door is opened first and these sensors are activated before the entry delay times out. So for example I open an external door,  panel starts beeping, I don't enter the code and I open an alarmed internal door. The internal sounder activates, but not the outside bell. (didn't check if there's a delay before it actually does)
Are these zones walk through by default?
Marked as access , not sure if they would do what your saying tho, under menu zone options
Checked all the zone types. All "alarm" except a panic zone and entry/exit door zone.
Checked all the zone types. All "alarm" except a panic zone and entry/exit door zone. However the zone options are "inhibit". I thought this function on a zone was for allowing the panel to be armed even if the zone is active?
Zone options "access"
Not talking about zone type
You would want to keep a PIR with access option as yes if it's in the entry route , but perhaps the door needs to be turned off , but I didn't think it would do what your describing but maybe
Posted (edited)
The door isn't in the entry route and I want it to trigger the alarm immediately when opened, so is inhibit the correct option? The other options are access, excl from part set A, excl from part set B, double knock, soak, chime, 24 hour, perimeter and remote test.
Edited by Eugene's DIY Den
You read what I am saying lol?
Is the internal door set for access option in menu set to yes or no?
48 minutes ago, Eugene's DIY Den said:
Not sure what you mean. The zone type for the internal door is "alarm"  and  the zone option is "inhibit".
Ok but if you scroll through you will find chine , access, blah
