al-yeti Posted March 2, 2020 Posted March 2, 2020 13 minutes ago, Eugene's DIY Den said: The panel I used is a pro version, I was lucky enough to get it from my electrical suppler. Apparently it's only supposed to be supplied to professional , not sure of the logic of this? Maybe they're afraid of reverse engineering? Maybe , you got details of who supplied to you? Quote
Eugene's DIY Den Posted March 2, 2020 Author Posted March 2, 2020 (edited) 3 minutes ago, Logan said: I use orisec and you must be a registered installer to purchase thier equipment In case you're a burglar and hack in and remotely control the panel in the future? I presume that's what they're worried about. Edited March 2, 2020 by Eugene's DIY Den Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
norman Posted March 2, 2020 Posted March 2, 2020 33 minutes ago, Logan said: I use orisec and you must be a registered installer to purchase thier equipment That should be easy then.... Quote Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted March 2, 2020 Posted March 2, 2020 55 minutes ago, Logan said: I use orisec and you must be a registered installer to purchase thier equipment Thought used enforcer , mini and all that? Quote
MrHappy Posted March 2, 2020 Posted March 2, 2020 1 hour ago, Logan said: I use orisec and you must be a registered installer to purchase thier equipment did you get an adult to fill out the form ? Quote Mr Veritas God
Eugene's DIY Den Posted March 2, 2020 Author Posted March 2, 2020 I notice I get an error fault sometimes when I open my front door and the alarm goes off. The frame is swollen with all the rain so the door takes a lot of tugging and pushing to pull it open. Could this be due to the contacts being repeatedly opened and closed, sending multiple pulses to the panel instead of a single open signal? Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
MrHappy Posted March 2, 2020 Posted March 2, 2020 16 minutes ago, Eugene's DIY Den said: I notice I get an error fault sometimes when I open my front door and the alarm goes off. The frame is swollen with all the rain so the door takes a lot of tugging and pushing to pull it open. Could this be due to the contacts being repeatedly opened and closed, sending multiple pulses to the panel instead of a single open signal? tamper due to poor connections... 1 Quote Mr Veritas God
al-yeti Posted March 2, 2020 Posted March 2, 2020 28 minutes ago, Eugene's DIY Den said: I notice I get an error fault sometimes when I open my front door and the alarm goes off. The frame is swollen with all the rain so the door takes a lot of tugging and pushing to pull it open. Could this be due to the contacts being repeatedly opened and closed, sending multiple pulses to the panel instead of a single open signal? Put a surface mount on , not ideal may work better for you , if difficult to keep connection in frame Quote
Eugene's DIY Den Posted March 2, 2020 Author Posted March 2, 2020 2 hours ago, MrHappy said: tamper due to poor connections... Connections are perfect, I always spend ages making them. No corrosion. Fault wasn't a tamper fault. Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
Eugene's DIY Den Posted March 2, 2020 Author Posted March 2, 2020 1 hour ago, al-yeti said: Put a surface mount on , not ideal may work better for you , if difficult to keep connection in frame There's no movement of the sensors though, they're well fixed. What I'm wondering is what exactly "entry fault" means. Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
