Hi Chaps
Wondered if you could help.
Ive a Scantronics 9651 with engineers codes etc.
i recently moved a PR Sensor for decorating and tripped a fuse on the board. While out of use (awaiting fuses) I took the opportunity to remove the keypad and clean the contacts as several buttons were not working properly.
Afterwards I changed the relevant fuse and despite having codes I’m unable to reset my system from a Bell Temper & Aux  DC Fault.   Any tips would be gratefully appreciated.
many thanks
Steve
Do you have a multimeter OP?
Also send us a picture of your PCB so we can see the exact model (though if it has fuses suspect which one it will be) but good to check.
On 01/03/2020 at 11:49, Logan said:
Did you check the other fuses
Hi
Yes, two fuses on the circuit board and the  remaining two all intact.
steve
44 minutes ago, Steve89 said:
Hi
steve
Do one thing at a time
First disconnect the pirs etc from the 12v aux  , you need keypad on tho of course and link the bell tamper
This should prove panel is working if those faults clear
