al-yeti Posted March 7, 2020 Posted March 7, 2020 4 minutes ago, GalaxyGuy said: Apps are fairly easy to overcome though, so you're relying on your employees at the end of the day. App access is just first layer Then you need seed So doubt employees bothered Quote
norman Posted March 7, 2020 Posted March 7, 2020 Still more difficult than begging for a code on one of the Facebook groups, they usually take a few minutes to disclose them. Quote Nothing is foolproof to a sufficiently talented fool.
sixwheeledbeast Posted March 7, 2020 Posted March 7, 2020 You are relying on your employees but you wouldn't have taken them on in the first place if you didn't have some trust in them. Your going to struggle to stop people keeping there own lists but this is only the same as having individual passwords for every website login which is recommend. Having the "app" on your company website behind an engineer login portal is another option. Quote
al-yeti Posted March 7, 2020 Posted March 7, 2020 6 minutes ago, sixwheeledbeast said: You are relying on your employees but you wouldn't have taken them on in the first place if you didn't have some trust in them. Your going to struggle to stop people keeping there own lists but this is only the same as having individual passwords for every website login which is recommend. Having the "app" on your company website behind an engineer login portal is another option. You think changing codes on annual inspection is ideal or makes it more complicated? Quote
norman Posted March 7, 2020 Posted March 7, 2020 Nah, bad idea imo Quote Nothing is foolproof to a sufficiently talented fool.
Alarmbloke Posted July 22, 2020 Posted July 22, 2020 On 03/03/2020 at 20:54, tinnitus said: Hi guys, can you help settle an argument? Is it an nsi gold requirement that the engineer code be changed when an employee (engineer) leaves the company? Or is it just good practice? Also, should it be changed annually? thanks in advance. I dont see the point to a certain extent,when most panels, with a competent engineer can default,change engineer codes if wanted to take over, so even if companys hide or constantly change codes, seems a big loss of hours Quote
james.wilson Posted July 24, 2020 Posted July 24, 2020 Imo it should be a full default, God knows what your inheriting without 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted July 24, 2020 Posted July 24, 2020 It depends if you have a procedure of locking panels, there is no loss of hours it's systemic as you to maintenance. It just means you have more codes for your engineers to remember which inherently means they are often written down somewhere. Unique codes or POTD is a better option, could be accessible via company login as I outlined above. If all of your customers have the same code and that is shared via some Facebook group or whatever, how can you say that any of your systems haven't been messed with between visits. The only reason it's any less of an exploit is you have to be onsite at the keypad to program most panels at the moment, if this was online security you'd have lost control of your whole estate in 10 minutes. Quote
PeterJames Posted July 24, 2020 Posted July 24, 2020 I wonder how easy it would be to change a few hundred engineer codes via udl? Quote
Amps Posted July 25, 2020 Posted July 25, 2020 If the system is a Pyronix, setup for UDL and UDL enabled in the user menu(default is enabled) an ex engineer can login anytime he likes via the cloud and play around with the settings without any alert being created I have no idea if each insite download is registered to a user but hopefully it is. Quote
