james.wilson Posted March 6, 2020 Posted March 6, 2020 4 minutes ago, al-yeti said: Veritas electrician panel Premier put in by electrician mostly not set up right id say thats a lot Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted March 6, 2020 Posted March 6, 2020 Any panel can be put in wrong, different areas seem to have there own sparky panel of choice. Kit options as in the panel is modular by design with an array of module options for every problem. The aesthetics of all the kit is far superior too. Some of the things I remember are lack of:- wiring types, custom outputs, output types, users, log events and on the bigger panels Areas and Zones which is a niche use case but I have fitted 640's in the past. Quote
al-yeti Posted March 7, 2020 Posted March 7, 2020 1 hour ago, sixwheeledbeast said: Any panel can be put in wrong, different areas seem to have there own sparky panel of choice. Kit options as in the panel is modular by design with an array of module options for every problem. The aesthetics of all the kit is far superior too. Some of the things I remember are lack of:- wiring types, custom outputs, output types, users, log events and on the bigger panels Areas and Zones which is a niche use case but I have fitted 640's in the past. Yes agreed premier is closer to the dimension etc For domestic they are getting better , with newer keypads and contacts things will improve Hkc slow to introduce things but it's not a bad thing as it's not just thrown in desperation like orisec I like the flush mounts on the texe tho Quote
