I would also be looking to see if I can come out of one of the first floor rooms that back on to the flat roof, and tube around the inside
19 hours ago, sixwheeledbeast said:
Upto you on the aesthetics really, clips look terrible on render like that.
Personally I'd be thinking white 20mm conduit female ends straight into vandal resistant domes.
Drill through the corner for the back one. This is all if you can't do it from inside of course.
I imagine if someone did it on cost, cable ties down the drain pipe lash it across the flat roof but you did say you came here for professional advice.
Poor advice laying across flat roof
On 12/03/2020 at 00:15, al-yeti said:
in most parts of UK it will survive
I very reluctantly put my parents DVR in their boarded out loft, quite shallow, slate roof, the HDD lasted about 2 seasons...
I have some running for years still no issue
