Evening all, new member on here so hopefully can get some good info and give some out
Just wanted to find out for IP systems mainly HIK, do the PTZ (mainly DE range) need extra power, like 24 ac or even Hi-POE or is the 16 channel NVR enough to give out power?
Thanks
Thanks
Model in specific ?
Some require Poe power some don't , if it's poe NVR and Poe camera should be ok
Otherwise what's the full model number
Any him ptz's I've fitted have needed additional power.
The camera comes with either a PSU or Poe injector in the box.
Grant
Hik*
Grant
Hik*
Poe injector is used for?
Lol
Lol
Powering the camera as the Poe port on the back of the NVR doesn't put out enough power?
It's still Poe tho dude
All goes back to model of camera simple
NVR is DS-7616NI-K2/16p, ptz's are DS-4225-IWDE. Probably going to be a total of 3 PTZ.
Think thats more than the NVR can put out really
So NVR 12w per output max fully loaded ?
And seems 18w for the plus 7 with ir
You fully loading NVR? I wonder whats max output per port can't be 12w
