I recently moved into a flat which is provided by a housing association, it came with an alarm but the landlord did not know the code as it was not installed via them can you find the reset codes online or do you need a registered engineer to reset it
from what I can see the alarm is obsolete, but I seen a 4gen version guide is this the 4th gen version?
  On 17/03/2020 at 23:08, norman said:
Was it listed on the inventory?
Expand
Nope it was not, plus the flat was unfurnished, the landlord did say prior though due to signing the tenants they were installed by tenants but others with the same alarm has reset them online. Issue is I don’t want to mess with it
But I'd say if it's in when you rent then it's reasonable for you to expect it to be working.
It is really the landlords responsibility, however, an alarm is not an essential utility like gas water or electricity  so I suppose he could argue that its not necasary for him to supply it in  working order.
That said if the alarm was to fail and start sounding at silly oclock in the morning and you have no way of stopping it who is responsible then?  If I was the landlord I would have had it removed  before renting it out if I wasn't going to look after it.
If you as the tenant take on the responsibility you should get written permission from the landlord to cover yourself. Then you should call a few local companies and get some quotes to have it looked at professionally. I would recommend you use an accredited company  or one that can be recommended by someone you know and trust. Dabbling with it yourself could end up with a lot of annoyed new neighbors,  dont under estimate what could go wrong .
There are plenty of landlords that have a system for when the property has no tenant and wouldn't include it in the lease.
I agree with above regarding getting written permission if you want to go that route, but expect to take on the responsibility of it including having it serviced annually, any repairs and faults etc.
On the itinerary it should have been itemised and noted as not working etc. this covers the landlord and also records it as their property.
"Issue is I don’t want to mess with it"
I'd agree you shouldn't and that leaves you with 3 options
  • either speak to the housing association/LL about having it repaired - guessing it will be a no judging by your comment thus far
  • ask if you can arrange for it to be looked at, at your cost - as above keep a record of this
  • leave it and hope it won't go off
Logan did you read any of the posts above?
i understand your trying to be helpful but there is a much bigger picture you need to think about in real world situations.
Ownership, liability and responsibility in this case for example.
  • Upvote 1
