Smart Electrics Posted November 22, 2004 Posted November 22, 2004 Has any one come across this before on the Gardtec593. Situation. New system out of box ordered for the customer in march. After connecting all connections found that PIRs would stay illuminated and RKP would go through random sequences and then go blank (Key Pad is LED type) After checking voltages I found that Aux is running at about 8Vdc and the other + connections are fluctuating from 8 to 12. DC charging OK? and AC input after step down is running at 19vAC. Obviously a power problem after rectifyer but has any body ells had problems resonately
Chris Teague Posted November 22, 2004 Posted November 22, 2004 It was about March that we had a batch of about 4 593's (Poly Carb Case) that all had dry joints around the fuse holder on the PCB. It would drop out the Aux, loose the RKP for a while and activate the Hold Off on the SAB. We re-soldered them on site, but did raise it with Gard Tec as an issue, as we also had a couple of 840's with loose fuse holders too. Never got a proper response though, and to be honest, we were too busy to pursue it with them at the time, but we have not had any such problems since. Chris Teague (Sales & Operations Manager) Sightguard Intruder Division Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440 Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
Smart Electrics Posted November 22, 2004 Author Posted November 22, 2004 lads for your replys. Ile get hold of gardtec tommorow and ask for a new board. I am getting a little Peed of with there equipment at the moment I have aslo been having problems with there diallers and Eurosec housings blody pain in the back side when you arive at site to install to then tell the customer you got to go back as the kit is faulty. I have started to go over to Menvier but I do like gardtec kit. (well Did)
