Hello,
I came across a Scantronic 9600 System today, they are a bit before my time.
When performing the procedure of defaulting the Engineer code due to the age the IC8 chip it was brittle and damaged.
On the chip were 2 lines as follows
93CS66B1
92A422
My question is, is it as simple as getting a new chip and popping in then setting up again or is there more to it?
Also found a similar post and this was recommended for the replacement chip, would this work?:
https://www.google.com/search?q=24C16%2FM24C16-WBN6P+DIP-8+Serial+I²C+Bus+EEPROM&oq=24C16%2FM24C16-WBN6P+DIP-8+Serial+I²C+Bus+EEPROM&aqs=chrome..69i57j69i58&sourceid=chrome&ie=UTF-8
Thanks in advance!
-Thomas
5 minutes ago, MrHappy said:
yes, but its 20 odd year old tat...
I know, it’s just to get it running before an upgrade is proposed.
Just to confirm, the chip linked below will work and is just plug in and play?
Thanks again
Thanks again
Scrap
  • Thanks 1
I'd just measure the circuits,
