Guest miketubby Posted November 22, 2004 Posted November 22, 2004 Guys, I've got my self-installed (not quite DIY as I have professional help) Galaxy system up and running (more details in another post) and I have SMS paging working, but I had to do a bit of a hack to get it going... My phone is on Orange. Orange have two SMS access numbers 07973 100601 and 07973 100602, neither of them seem to work correctly when configured for SMS paging (TAP protocol) using a Telecom Module (version 5) and Galaxy 500 (4.39 firmware)... The 'hack' I've done to get SMS paging working is to switch to the Cellnet/O2 SMS centre number and rely on the inter-network (02 to Orange) to get the messages through, to the centre number I've programmed is 07860 980480 and this accepts the TAP protcol from the Telecom Module just fine. Has anyone got the Galaxy/Telecom Module direct dialling in to Orange - if so which number did you use and which protocol setting? Mike
Mister_Dave Posted November 24, 2004 Posted November 24, 2004 Mike correct me if im wrong but IIRC you have to use +44 on the centre number. Dave Oxendale York based security systems engineer.
Guest miketubby Posted November 24, 2004 Posted November 24, 2004 Mike correct me if im wrong but IIRC you have to use +44 on the centre number. 32508[/snapback] Dave, I don't think so... yes, if you are using MO (Mobile Originate), but this is land-line (PSTN) originate... thing is I'm not sure if Orange actually support TAP for SMS they have their own "text" protocol which is different Mike
Guest Posted November 24, 2004 Posted November 24, 2004 Dave,I don't think so... yes, if you are using MO (Mobile Originate), but this is land-line (PSTN) originate... thing is I'm not sure if Orange actually support TAP for SMS they have their own "text" protocol which is different Mike 32588[/snapback] galaxy recommend using the o2 service which works fine for me..have the no's for orange,t-mobile somewhere will dig them out..
Allso Posted November 25, 2004 Posted November 25, 2004 don't think so... yes, if you are using MO (Mobile Originate), but this is land-line (PSTN) originate... thing is I'm not sure if Orange actually support TAP for SMS they have their own "text" protocol which is different 32324[/snapback] Hi, This all sounds very complicated. Is there any advantage over a separate speech dialler that would dial your mobile and leave a voice message rather than SMS? Also, can you tell us how you manage to get you telecom module version upgraded in the end, or did you get a new one? Allso
mikeald Posted January 4, 2005 Posted January 4, 2005 as far as i know galaxy only recommend t mobile message centre. the number is: 07958879889. Still **** though as the telecom mod will only text to one mobile. An sd2 is the best. mike Intruder & Fire Member
amateurandy Posted January 4, 2005 Posted January 4, 2005 as far as i know galaxy only recommend t mobile message centre. the number is: 07958879889 Is that a typo?I think it's 07958 879 879, at least that's what's in my phone.
Guest Posted January 5, 2005 Posted January 5, 2005 Is that a typo?I think it's 07958 879 879, at least that's what's in my phone. 36089[/snapback] as far as i know they use different no's than the mobiles use,my galaxy use's the 889 no'
amateurandy Posted January 5, 2005 Posted January 5, 2005 as far as i know they use different no's than the mobiles use,my galaxy use's the 889 no' Thanks. You live and learn.
breff Posted January 5, 2005 Posted January 5, 2005 Texecom Premier Com2400 texts up to 6 numbers.... Come on Monteey lets start a galaxy bashing argument The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
