john01 Posted March 21, 2020 Posted March 21, 2020 Advice please. I was changing the battery on the Veritas 8. When I pulled out the earth lead from the old battery, The alarm went off (mains power was off). I put power back on and reset alarm to kill the external siren. I then noticed that the black and red wire wound together at the bottom left of picture was loose. Don't know whether it never was in a terminal or i knocked it out when i pulled the battery wire. Does anyone know where this wire goes please? Thanks in advance john Quote
PeterJames Posted March 21, 2020 Posted March 21, 2020 Earth lead? Where does the red and black come from? You have nothing it the strobe terminal but I cant imagine both red and black would come from there. Quote
john01 Posted March 21, 2020 Author Posted March 21, 2020 Yes Thanks Peter, I saw that empty terminal and did wonder but the terminal screw is very undone as if there never was anything in there! Quote
sixwheeledbeast Posted March 21, 2020 Posted March 21, 2020 I assume by earth you actually mean the black negative battery lead. Battery lead terminals on a Veritas are marked as BATT + and - I can't see your image so not sure if you are talking about something else. Quote
john01 Posted March 21, 2020 Author Posted March 21, 2020 Yes sorry I meant to say negative on the battery. Can you see this picture? Quote
PeterJames Posted March 21, 2020 Posted March 21, 2020 40 minutes ago, PeterJames said: Where does the red and black come from? Quote
PeterJames Posted March 21, 2020 Posted March 21, 2020 Not sure why the picture has gone it was a red and black wire twisted together lose in the panel. I would put everything back together a bit of tape over the wire and see if everything works, walk test bell test ect Quote
john01 Posted March 21, 2020 Author Posted March 21, 2020 I wasn't able to see behind all the wires unfortunately. Quote
sixwheeledbeast Posted March 21, 2020 Posted March 21, 2020 I can't for whatever reason. You can attach images in the post if you need Quote
PeterJames Posted March 21, 2020 Posted March 21, 2020 Just now, sixwheeledbeast said: I can't for whatever reason. You can attach images in the post if you need He did but its gone, I had trouble the other day with pics maybe James is doing something with the Server Quote
