zbm2 Posted March 28, 2020 Posted March 28, 2020 Hi everyone, Apologies if this has been asked before, but I have been unable to find an answer. I have an Optima XM home alarm and need to remove 2 PIRs after some building work was done on the house. I know which zones relate to which PIRs after doing a walk test. Could someone provide step by step instructions on how to do this please. Also, after disconnecting the power and taking off the front panel and then reversing, all LEDs are now on and all buttons unresponsive - is this normal and will the panel return to normal after a set amount of time? Thanks in advance! Quote
james.wilson Posted March 28, 2020 Posted March 28, 2020 you will need to enter your code after powering it back up. Or press reset im unsure. But if you have faults it wont let you reset it till the faults are cleared, ie dont exist anymore Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
PeterJames Posted March 28, 2020 Posted March 28, 2020 41 minutes ago, zbm2 said: Hi everyone, Apologies if this has been asked before, but I have been unable to find an answer. I have an Optima XM home alarm and need to remove 2 PIRs after some building work was done on the house. I know which zones relate to which PIRs after doing a walk test. Could someone provide step by step instructions on how to do this please. Also, after disconnecting the power and taking off the front panel and then reversing, all LEDs are now on and all buttons unresponsive - is this normal and will the panel return to normal after a set amount of time? Thanks in advance! Did you disconnect the battery when you down powered? Quote
sixwheeledbeast Posted March 28, 2020 Posted March 28, 2020 Panel will lockout if in tamper, you need to disconnect the PIR's panel end and close the tamper loop up then it should clear. Quote
zbm2 Posted March 28, 2020 Author Posted March 28, 2020 1 hour ago, PeterJames said: Did you disconnect the battery when you down powered? Disconnected power, then battery, then connected back up in reverse order. Alarm sounded and was able to put in code, which silenced the alarm. 'Day' and 'Power' LEDs now lit, so looks to be in a normal state. Thank for the help. Would anyone know how to safely remove a PIR from the system please? Quote
james.wilson Posted March 28, 2020 Posted March 28, 2020 remove all the cabling for it in the control panel, power and circuit. YOu will then have to remove the tamper from the loop and link out the circuit Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
zbm2 Posted March 28, 2020 Author Posted March 28, 2020 2 minutes ago, james.wilson said: remove all the cabling for it in the control panel, power and circuit. YOu will then have to remove the tamper from the loop and link out the circuit Cheers, will give it a go! Quote
PeterJames Posted March 28, 2020 Posted March 28, 2020 32 minutes ago, zbm2 said: Disconnected power, then battery, then connected back up in reverse order. Alarm sounded and was able to put in code, which silenced the alarm. 'Day' and 'Power' LEDs now lit, so looks to be in a normal state. Thank for the help. Would anyone know how to safely remove a PIR from the system please? Connect power first then battery NOT battery first, if the battery is knackered the psu wont be able provide enough power to the controls Quote
