EViS Posted April 5, 2020 Posted April 5, 2020 I am planning to secure a boundary with external Optex beams and XDL12TT detectors all connected to a Pyronix Enforcer Control Panel V10. I will not be installing an external bell box and merely want to be notified inside or via push notifications. How loud is the Enforcer panel's internal sounder? Is it likely to be loud enough to wake me up/alert me of any triggers whilst being located 10m away in a cupboard? Additionally, is there a secondary buzzer I could connect wirelessly and site internally on the other side of the property? Quote
Guest Posted May 31, 2020 Posted May 31, 2020 4 hours ago, aissecur said: Yes I think it’s about 109db Its 100db Quote
aissecur Posted June 1, 2020 Posted June 1, 2020 On 31/05/2020 at 11:39, Logan said: Its 100db Near enough Quote
Guest Posted June 1, 2020 Posted June 1, 2020 (edited) 59 minutes ago, aissecur said: Near enough Maybe Edited June 1, 2020 by Guest Quote
aissecur Posted June 2, 2020 Posted June 2, 2020 On 01/06/2020 at 21:29, Logan said: Maybe Not sure I follow, have you been sniffing urinals ? Quote
Guest Posted June 2, 2020 Posted June 2, 2020 46 minutes ago, aissecur said: Not sure I follow, have you been sniffing urinals ? No ive been stuck at home Quote
