Hi i am currently replacing my old alarm  with a Visonic wireless system but after fitting some of the pet PIR's I am finding they are not very sensitive at all, they do work and I have moved them down the wall a bit but they still don't seem that good. Has any one got any tips or is this normal? Thanks a lot, Gary
Thanks for that I did not know if i was going wrong somewhere. luckily I am keeping some of the wired ones for the E/E. Thanks again
7 minutes ago, sixwheeledbeast said:
They're are not great pickup on the default settings and are useless outside the strict mounting height in the manual.
Do they have a settle down time like the Honeywell , they trigger once in 3 mins something like that?
You can lower the pulse count but you'll loose the pet friendly mode.
Yes they are one way, so also sleep for a few minutes in normal operation mode.
It's one way and pet friendly I wouldn't expect much guaranteed protection from it.
4 minutes ago, gazza_2 said:
al-yeti, that's what I was wondering
Are the Visonic one's classed as cheap?
depends on what you class as cheap. I think so yes, acceptable but low end. A decent hard wired pet tolerant sensor is more than a wireless visonic one. But i dont like them as a theory. If you have pets then peremiter protection is the way to go imho
