al-yeti Posted May 3, 2020 Posted May 3, 2020 3 minutes ago, MrHappy said: I had hiwatch camera on port 85 on the bench the other week & knew my work router to house router was working on port 85 in the past it appears the controls do not take up the software changes until power cycled or a code in entered on the psychical keypad however the downloading software still won't load on the intended win8 machine, the same file loads on my lenovo & acer laptops there all 64 bit machines.... You opening a can of worms Let's talk about hiwatch, why you got that on the bench , re badging to hikvision only ? So it becomes pro stuff Quote
MrHappy Posted May 3, 2020 Author Posted May 3, 2020 as this is public I will answer via PM Quote Mr Veritas God
al-yeti Posted May 3, 2020 Posted May 3, 2020 1 hour ago, MrHappy said: should you change the banner text- download it into the controls, the old banner is displayed until the user code is entered, odd... So any chance in switching to ion as your main panel or dropping the enforcer for this Scanny wireless have an all in one? Onboard keyboard jobby? Quote
MrHappy Posted May 3, 2020 Author Posted May 3, 2020 57 minutes ago, al-yeti said: So any chance in switching to ion as your main panel or dropping the enforcer for this Scanny wireless have an all in one? Onboard keyboard jobby? I like the square i-ion keypad & massive endsation But won't be moving towards them. Quote Mr Veritas God
al-yeti Posted May 3, 2020 Posted May 3, 2020 6 hours ago, Logan said: Still prefer enforcer True , DIY is good for you Quote
al-yeti Posted May 4, 2020 Posted May 4, 2020 27 minutes ago, Logan said: Diy? I dont install this yellow peice of S*** But you are DIY ? DIY prices , DIY installs ? Quote
al-yeti Posted May 4, 2020 Posted May 4, 2020 9 hours ago, MrHappy said: I like the square i-ion keypad & massive endsation But won't be moving towards them. Eaton scantronic I know your reading this , helicopter above forum You missed the boat , need all devices two way , I might have switched to ion aswell Only reason they keep app platform free is because they probably collapse by now if they didn't Quote
sixwheeledbeast Posted May 4, 2020 Posted May 4, 2020 Being NSI Gold goes way beyond how tidy the wiring is in the panel. that's likely down to one engineer and their untidy workmanship. There is a whole company, employees. training, testing, maintenance and audit trail behind that job. Quote
MrHappy Posted May 4, 2020 Author Posted May 4, 2020 2 hours ago, Logan said: Erm my installs are done better than some NSI gold companies btw i dont use the enforcer unless i have to I mainly still install wired systems of all the systems i installed i only used 1 enforcer panel as i wasn't able to run cables as the house was Newly decorated Is that battery dated ? If so why would you have to move the battery it to see the date ? Those alarm cables marked? Why have you got main & low voltage shoved though the same ungrommeted hole ? Why is there no stress relief for the mains If you wish to post an example of your specification that's when the proper fun starts... Quote Mr Veritas God
james.wilson Posted May 4, 2020 Posted May 4, 2020 Quote Terminal Allocations: A Relay (see p.xx-xx) 1 C contact 2 NC contact 3 NO contact im guessing whatever is connected to A3 doesnt work very well? also you have a .5mm 2 core flex whats that doing? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
