MrHappy Posted April 18, 2020 Share Posted April 18, 2020 2 hours ago, Logan said: Mk3 looks like 1960s tat MK3 is probably the best looking ? The thorn one looked 70's sci-fi prop... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
norman Posted April 18, 2020 Share Posted April 18, 2020 Galaxy have always been behind the curve with aesthetics imo, the mk7 is my preferred one, the mk8 looks gash for a modern day bit of kit. 9600 was awesome by comparison but the recent Texe would be my choice. 2 Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
norman Posted April 18, 2020 Share Posted April 18, 2020 Talking about aesthetics only here though not functionality etc. so will be more subjective. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
al-yeti Posted April 18, 2020 Share Posted April 18, 2020 2 hours ago, Logan said: Im not really a fan of texecom i do like the veritas though My favourite panels are Scantronic Galaxy Pyronix euro series This is blag Quote Link to comment Share on other sites More sharing options...
MrHappy Posted April 18, 2020 Share Posted April 18, 2020 10 minutes ago, Logan said: No this is sparta 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
MrHappy Posted April 18, 2020 Share Posted April 18, 2020 23 minutes ago, Logan said: Any luck with the ion i sent you? its on the desk waiting for me to mess, Quote Mr Veritas God Link to comment Share on other sites More sharing options...
datadiffusion Posted April 18, 2020 Share Posted April 18, 2020 (edited) 2 hours ago, MrHappy said: its on the desk waiting for me to mess my pants with excitement disgusting. glad you saw fit to edit it. Edited April 18, 2020 by datadiffusion 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
Steve23 Posted April 27, 2020 Share Posted April 27, 2020 On 17/04/2020 at 12:06, GalaxyGuy said: I'm currently working on a virtual RIO module as part of something that I want for my own home automation. I'll sell this for the bigger panels like the FX100+ and GD96 upwards, as they have lots of links available. The virtual RIO sits on the RS485 bus and will consume 4 addresses, giving 16 outputs and 32 inputs in virtualised form. On my own system, I currently have lots of outputs programmed to switch lights, heating and garage door Etc, but I either control them from the app, or guard codes. I've been looking at OpenHab, so would like a way for linked zones with virtualised outputs to provide the OpenHab 'things' with status update calls over IP. There shouldn't be any reason that the virtualised RIO cannot send the calls to any other controller, it's just a matter of the appropriate protocol. This is basically what some of these other hardware vendors do for Vista, but instead of the compatible device, they physically hook into the existing zones and outputs wiring. This would cause an issue for the Galaxy, as it uses balanced circuits, so any external influence on the circuits would cause problems. The virtual RIO will only need connected to the bus and an Ethernet connection, so a simple addition. Since the inputs and outputs are programmable, it's entirely up to the person who configures the system as to the level of control allowed. An input call to the virtual RIO could set a zone as active and in turn fire another physical panel output, or set the system. Basically anything that the panel is capable of. For me, I think the timers and sequence based logic is limited on the Galaxy, and that's where the home automation excels. I like the sound of that I was hoping for some way besides Konnected to link my Flex into my SmartThings. I was hoping I could do it a similar way to a standard 12v doorbell I have. So I have a Xiaomi ZigBee push button thats on my SmartThings setup and it has contacts on that replicates the button been pressed, so I connect them to the led on the bell receiver so when the bell goes of it activates the button and then I can do what I want with that within SmartThings. I wouldn't know where to start with the flex I just followed a guide to do the bell. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted April 27, 2020 Share Posted April 27, 2020 23 minutes ago, Steve23 said: I like the sound of that I was hoping for some way besides Konnected to link my Flex into my SmartThings. I was hoping I could do it a similar way to a standard 12v doorbell I have. So I have a Xiaomi ZigBee push button thats on my SmartThings setup and it has contacts on that replicates the button been pressed, so I connect them to the led on the bell receiver so when the bell goes of it activates the button and then I can do what I want with that within SmartThings. I wouldn't know where to start with the flex I just followed a guide to do the bell. Maybe he needs a field tester 1 Quote Link to comment Share on other sites More sharing options...
al-yeti Posted April 28, 2020 Share Posted April 28, 2020 22 minutes ago, Logan said: Well it tests fields Of grass Drug dealer? Quote Link to comment Share on other sites More sharing options...
