Regs on Home Control
11 minutes ago, scrimshanker said:
Hi
Could someone enlighten me on the regs regarding the setting and unsetting of an alarm using a home control system such as Control 4 instead of the keypad of the alarm.
As long as the component doing the disarming meets the component requirements of en 50131 then you can certificate it
  • Upvote 1
Link to comment
Share on other sites
Setting time must be a minimum of 30 seconds with the setting alert audible throughout the premises. That’s about I think although no one uses the 30 second thing or the audible throughout the premises parts :lol:
Link to comment
2 hours ago, scrimshanker said:
is this an oversight as insurance companies must request police response for these houses due to the cost of them and they aren't compliant, or is police response a thing of the past and insurance companies just require key holder?
There is no way to control 3rd party integrations if the provider doesn't have 3rd party certification. Its a want these houses have not a need. Think about what would happen if the system failed to perform. The certification company would be taking all the risk on a system the installer / maintainer has no control over. I believe these integrations rely on engineer level access between them. Any installer doing this without the necessary protection is daft IMHO.
There is a 'guide' being worked on but the scope is so massive there is no time line if it ever sees the light of day.
  • Upvote 1
Link to comment
That's only for remote arming apps as part of the system IIRC. Third party connections are not going to conform to relevant EN's.
Link to comment
