2 hours ago, james.wilson said:
also need a tidier way to do the other ends as im not keen
I tried cds they never worked for me so got a cat , now he kills the birds and I have to deal with feathers
5 minutes ago, MrHappy said:
Optex internal PIR, painted black & slapped on the wall outside ?
Yep i added a few after my hkc test to see how others did. The optex DT is coming down the honeywell dt is moving from the front to back to check its not environmental as the sun rises that side. Ive decided the optex dt doesnt like sunlight
Not tried one. The constant is a voltek pir with a pulse count module on it. However they dont like the animal activity so i started with other things. HKC quad so far (on low sens) has the best catch vs FA) The optex is very poor as it hates the sun (i know its outside but its a dt on its lowest settings) the honeywell dt is pretty stable but still worse fa due to deer so im still testing etc
Looking good, keep the updates coming.
Nice big garden BTW. What lawnmower did you opt for?
