Tens6306 Posted Tuesday at 04:57 Posted Tuesday at 04:57 10 hours ago, al-yeti said: So going back it seems you think both keypads work But are sending line 2 downstairs Why not just put everything on to line 1? None of the lines are working, not even line 1. If I connect my keypads to the other panel (new) it works perfectly. So I now know the issue is with the panel and it affects all the AB lines. Is there a way I can get this fixed or what could be the problem? Quote
al-yeti Posted Tuesday at 06:22 Posted Tuesday at 06:22 1 hour ago, Tens6306 said: None of the lines are working, not even line 1. If I connect my keypads to the other panel (new) it works perfectly. So I now know the issue is with the panel and it affects all the AB lines. Is there a way I can get this fixed or what could be the problem? Well I assume eBay new panel doesn't work so forget it Quote
james.wilson Posted Tuesday at 14:51 Posted Tuesday at 14:51 so even if you only have 1 keypad connected on line 1 addressed as 1 it still doesnt work. Have you also tried a temp small cable just out of the panel to prove the wiring? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
