10 hours ago, al-yeti said:
So going back it seems you think both keypads work
But are sending line 2 downstairs
Why not just put everything on to line 1?
None of the lines are working, not even line 1. If I connect my keypads to the other panel (new) it works perfectly. So I now know the issue is with the panel and it affects all the AB lines. Is there a way I can get this fixed or what could be the problem?
Well I assume eBay new panel doesn't work so forget it
