2 hours ago, PeterJames said:
In your shoes Id buy a grade 1 surface contact and remove the reed from that
This is worth the try
Providing you know how to solder and not butcher
I'd suggest it's past it. But if you want to keep it I'd bridge the Reed and use the external connections only. But as its the oldest electronic thing in your house it must be time to upgrade or if your not fussed just decommission it
You ought to look into wireless polling etc not just assume a signal will make it. The rf environment is way different now than when that was considered good
  • Upvote 1
Actually that might be better but you could also cut the reed up top and use the legs to solder to rather than messing the board up
Agreed about rf
Posted (edited)
Exactly if it's the on board reed, just wire externally and jumper the on-board.
(I mean honestly I'd bin the lot as discussed ad-infinitum but that is at least a no-solder solution)
Edited by datadiffusion
Changed the reed switch. All works fine now. Good for another 20 years
Thank you so much to everyone that responded
  • Upvote 1
LOL!
Good job
Although 20years? Hahaha
well done,
you'll now be able to put you feet up & listen to your 8 track or maybe give your talbot solara another coat of autoglym...
  • Upvote 1
