Eddie Marshall Posted April 24, 2020 Posted April 24, 2020 I would like to disconnect the power to the 800i box if I switch the power off and unscrew black and red would that set off alarm when I throw mains back on Quote
Eddie Marshall Posted April 24, 2020 Author Posted April 24, 2020 800L box because it’s a constant beep and can’t stop the tpr if I unwire it will it set the main alarm off Quote
sixwheeledbeast Posted April 24, 2020 Posted April 24, 2020 It would not be advised to remove wires from the alarm system if you don't know what your doing. Removing power from the controls should normally trigger the alarms hold-off making the external alarm sound as if it where tampered with.. Quote
al-yeti Posted April 24, 2020 Posted April 24, 2020 2 hours ago, Eddie Marshall said: I would like to disconnect the power to the 800i box if I switch the power off and unscrew black and red would that set off alarm when I throw mains back on Is there an external bell box? Do you have a fused spur ? That you remove the fuse Quote
