Guest aechlin Posted November 23, 2004 Posted November 23, 2004 Hi Does the 690ID have to use Menvier biscuits or can any other make of addressable biscuits work with it comfortably? Alistair
Monteey Posted November 23, 2004 Posted November 23, 2004 Im not aware that menvier make biscuits, TS690ID panels use the ADE iD biscuits Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
logical Posted January 13, 2005 Posted January 13, 2005 Im not aware that menvier make biscuits, TS690ID panels use the ADE iD biscuits 32418[/snapback] they do make bicuits but they arent as good as mcvities Trade Member
Guest Adrian Posted January 15, 2005 Posted January 15, 2005 B) Just check that you use ID chips and not the resisters that may come in the pack, I worked with an engineer once that spent 40 mins trying to figure out how to wire the resisters to the ID line If you have a problem drop me a line I have one of these in my home. Adrian B)
