Can any one help my accenta alarm is not working the spanner light is on my panel and I cannot set the alarm fitted a new battery. I’ve tried everything and it is going off randomly all the time?
is it an lcd keypad
if so you need to post your log history
Also when you fitted the new battery did the case or interior seem hot - how did you know you needed a new one?
2 hours ago, datadiffusion said:
Global sales
qfa
10 hours ago, Logan said:
Only the led keypads have the "spanner" light (tamper)
good point my bad
you have a tmaper fault that will need to be found and restored or bypassed to test the panel.
It wont reset until its cleared
