Ismail Pak Posted April 29, 2020 Posted April 29, 2020 Hi I got i-on Alarm and I got on screen says “SRN01 low battery “ so what battery need to be replace by the way I just changed outside one last month thanks in advance. Quote
al-yeti Posted April 29, 2020 Posted April 29, 2020 4 hours ago, Ismail Pak said: Hi I got i-on Alarm and I got on screen says “SRN01 low battery “ so what battery need to be replace by the way I just changed outside one last month thanks in advance. Where did you get new battery ? Or you haven't reset it , perhaps tamper is still open or something if battery is good Quote
datadiffusion Posted April 30, 2020 Posted April 30, 2020 Should reset after engineer reset. As above suspect you've been sold duff battery - or possibly corroded / loose plug connection. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
