AgsDave Posted May 5, 2020 Posted May 5, 2020 Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. Quote
al-yeti Posted May 5, 2020 Posted May 5, 2020 On 05/05/2020 at 19:30, AgsDave said: Anyone know why a zone programmed as unused still shows as open when trying to set? I'm sure it's a simple thing, but not a panel I am familiar with. Expand You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal Quote
MrHappy Posted May 5, 2020 Posted May 5, 2020 I assume if shows open its needs a resistor or link in the terminal too Quote Mr Veritas God
james.wilson Posted May 6, 2020 Posted May 6, 2020 Is it well old? Might need a restart if the circuit was in use, then went fault before spared off Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Nova-Security Posted May 6, 2020 Posted May 6, 2020 Airitechs need to see a 4k7 EOL even if the circuit is programmed as unused. 2 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
AgsDave Posted May 6, 2020 Author Posted May 6, 2020 I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. On 05/05/2020 at 21:36, al-yeti said: You mean it's alerting you? Or on zone status when checking before setting? Don't about this panel ,but the latter point galaxy also shows tamper when spare but will set as normal Expand No it wouldn't set. I prefer galaxy all day long. But I guess it's what you get used too. Quote
datadiffusion Posted May 6, 2020 Posted May 6, 2020 Only ever serviced a couple of Aritechs never made any changes, didn't know that about resistance req. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Nova-Security Posted May 6, 2020 Posted May 6, 2020 On 06/05/2020 at 16:40, AgsDave said: I did fit an eol to solve the issue. Just wondered if it was something I had missed in the programming. Expand Airitech need the 4K7 EOL if the zone isnt used, not like a Galaxy where you can spare it with nothing in the zone Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
abbz Posted May 6, 2020 Posted May 6, 2020 (edited) On the older ones there were 2 attributes called unused. Never remember having to put resistor in unused cct Edited May 6, 2020 by abbz Quote
