Lak Posted May 6, 2020 Posted May 6, 2020 Hi, I have recently cancelled subscription to ADT, now my pm360r alarm keypad beeps constantly and has an orange warning triangle and troubleshooting error of plnk communication error. does anyone know how to permanently clear this or just stop the beeping? I still need use of the alarm but stopping the beeping would be great. thanks Quote
al-yeti Posted May 6, 2020 Posted May 6, 2020 2 minutes ago, Lak said: Hi, I have recently cancelled subscription to ADT, now my pm360r alarm keypad beeps constantly and has an orange warning triangle and troubleshooting error of plnk communication error. does anyone know how to permanently clear this or just stop the beeping? I still need use of the alarm but stopping the beeping would be great. thanks You need engineer access to switch off the coms , there's a few trade DIY visonic experts here , they may comment soon Quote
sixwheeledbeast Posted May 7, 2020 Posted May 7, 2020 Your unlikely able to fix it yourself. The comms module will need disabling in the engineers menu. You either need to get ADT to remove it or find an engineer that works on Visonic to remove it. Bear in mind support for ADT Visonic maybe limited when it comes to parts, ADT models are not compatible with standard Visonic if you need replacements. Quote
Lak Posted May 7, 2020 Author Posted May 7, 2020 20 hours ago, Logan said: I assume that you don't know the engineer code if you know the engineer code you can log in as a engineer and change the communication settings to not used If you don't know the engineer code the panel will require defaulting (or replacing if engineer locked) Hi, no I don’t have the engineer code, I will see if ADT would give me it (doubt it highly though). You mentioned defaulting, so that can be done without the code? Could I do that or need to call professional in? Quote
PeterJames Posted May 7, 2020 Posted May 7, 2020 2 minutes ago, Lak said: Hi, no I don’t have the engineer code, I will see if ADT would give me it (doubt it highly though). You mentioned defaulting, so that can be done without the code? Could I do that or need to call professional in? They wont give you it but they should default it for you for a charge of course. Quote
al-yeti Posted May 7, 2020 Posted May 7, 2020 45 minutes ago, Lak said: Hi, no I don’t have the engineer code, I will see if ADT would give me it (doubt it highly though). You mentioned defaulting, so that can be done without the code? Could I do that or need to call professional in? ADT don't lock there panels , or I haven't seen they do , so of you can work it out then yes you can default And then take 6months- a year getting it back to how it should work Shouldn't matter if security isn't that important Quote
Lak Posted May 7, 2020 Author Posted May 7, 2020 40 minutes ago, al-yeti said: ADT don't lock there panels , or I haven't seen they do , so of you can work it out then yes you can default And then take 6months- a year getting it back to how it should work Shouldn't matter if security isn't that important So defaulting the system will create problems? having the alarm working to arm everyday as it is currently is v important. Quote
james.wilson Posted May 7, 2020 Posted May 7, 2020 question OP, if its very important why have you cancelled the support etc on it? 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted May 7, 2020 Posted May 7, 2020 7 minutes ago, Lak said: So defaulting the system will create problems? having the alarm working to arm everyday as it is currently is v important. Yes So then get new engineer or new system some how Quote
PeterJames Posted May 7, 2020 Posted May 7, 2020 1 hour ago, Lak said: having the alarm working to arm everyday as it is currently is v important. Then why did you cancel the contract? If it goes wrong you're not covered, ADT generally dont fit external sounders so if you have a burglary, no one will hear it. Quote
