Just taken over a couple of ATS systems that have access on a few external doors.   Do these systems not have a timed egress function.  Every one you have to hold the rte and open the door, rte just wired across the lock feed.  Seems like a bodge way of doing it to me.
Is it wired across the lock feed for sure, did you check? I am not familiar with the ATS systems, but most access control panels have a RTE input. Normally the symptom you describe is because the RTE is wired into the controller as normally closed when it should be normally open or vice versa.
Allot of single door controllers are like this cheaper stuff so don't suprise me on the ats
Slightly surprised there isn't a zone attribute called Rex though, Siemens has both Rex zone and dedicated Rex on the door card iirrc. Not sure about texe?
Thanks for the replies.  Was just curious as to why the rte was inline with the lock feed, and if I was missing something obvious.  They look to be done using a transistor driven relay straight off the reader with data to the panel, And not via a door controller card.
