al-yeti Posted May 21, 2020 Posted May 21, 2020 1 hour ago, xpertalarms said: No bell delay programmed, ee tones are fine on both the keypad and ee horn for that group, but neither of them sound during alarm and the bells output type doesn't either Can you get a fourth group to output correctly? Quote
xpertalarms Posted May 21, 2020 Author Posted May 21, 2020 Tried a restart @james.wilson. there are 3 outputs programmed as bells, strobe and ee horn all assigned to A3 only without any modifiers. @al-yeti might try this, A1 and A2 work fine in the main building. Thanks Quote
xpertalarms Posted May 21, 2020 Author Posted May 21, 2020 Just now, al-yeti said: It's a d48? Yep Quote
Nova-Security Posted May 22, 2020 Posted May 22, 2020 (edited) Have a look at group status 53 - 7, should be a - for outputs to work all the time Edited May 22, 2020 by Nova-Security 1 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
xpertalarms Posted May 22, 2020 Author Posted May 22, 2020 7 hours ago, Nova-Security said: Have a look at group status 53 - 7, should be a - for outputs to work all the time That'll be the one. All sorted now, thanks @Nova-Security Quote
Nova-Security Posted May 22, 2020 Posted May 22, 2020 Glad it worked Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
