hey guys
Looking for abit of advice. My dads got a scantronic 9448 with a built in keypad. He'd like to relocate the control panel and just have a keypad. Is there any other keypads compatible with the control panel other than the 9427 keypad. He likes the KEY-KP01 but unsure if this will work.
Thanks
1 minute ago, Logan said:
The key-kp01 will only work with the ion panel
You can only use the 9427
Thanks for confirming that. Dam really as the 9427 are quite ugly. Is it the same case with the pirs or will any pir work?
2 minutes ago, Logan said:
Any pirs will work
If you plan to relocate the panel   you can upgrade the controls to something like a scantronic ion 30
Hes only just upgraded his panel to the 9448 as hes old one went faulty and just decided to change it like for like with the newer model.
Shame you could have almost certainly got a 9651 for the same money which is what it sounds like you are looking for now.
Get rid of panel
You mean he just replaced not upgraded
Might be ugly but if he really wants a keypad then you just use what's compatible, as it's a security device just tell him don't worry about it not smiling at you .... ?
