Sideshow Posted May 26, 2020 Posted May 26, 2020 Hi, After some help. I have 10 year old Eurosec alarm system, and when i went to change the internal battery i noticed a loose Blue wire, which i believe is the Trigger wire from the external alarm?. Any idea were this should connect to? I have also noticed that the external alarm has stopped working. Quote
james.wilson Posted May 26, 2020 Posted May 26, 2020 the bell trigger connection Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
PeterJames Posted May 26, 2020 Posted May 26, 2020 There are probably many wires that are not used inside a control panel do a bell test if it works then its not a bell wire. Then set it if it sets then its likely not a wire in use Quote
sixwheeledbeast Posted May 26, 2020 Posted May 26, 2020 I agree with PJ, was it stripped back as if it should be terminated somewhere? Quote
PeterJames Posted May 27, 2020 Posted May 27, 2020 29 minutes ago, Sideshow said: Bell test works and system sets okay I would guess that wire was unused then Quote
aissecur Posted May 28, 2020 Posted May 28, 2020 On 26/05/2020 at 21:02, Sideshow said: Hi, After some help. I have 10 year old Eurosec alarm system, and when i went to change the internal battery i noticed a loose Blue wire, which i believe is the Trigger wire from the external alarm?. Any idea were this should connect to? I have also noticed that the external alarm has stopped working. If you want to keep your system operational I do hope you change your battery more often than once every 10years Quote
al-yeti Posted May 28, 2020 Posted May 28, 2020 1 hour ago, Sideshow said: 2nd battery in 10 years So expect problems Quote
Guest Posted May 28, 2020 Posted May 28, 2020 1 hour ago, al-yeti said: So expect problems Nah he just has nieghbors who he really wants to annoy Quote
