Set the system and trip a NON exit entry zone. This should sound the bell.
if working on bell test then can only be there is a bell delay set or tripping an entry timed zone and not waiting until full entry time has expired.
You need to check the zine you trigger is programmed  as a 12hr (ie instant alarm on zone)
failing that press & hold 1 & 3 on the remote keypad to activate the panic, this will give you a full alarm condition
