11 minutes ago, james.wilson said:
Id say every 5 years is fine. Better to replace before panels report it to prevent damage but modern panels seem to do better with failed battery's than the old dumb stuff
Erm you said you thought the optima was a very good reliable panel
Forgot to mention the blue was stripped back as though it should be terminated somewhere.
Thanks for the replies so far.
Going to try this
Troubleshooting  :
External Sounder does not sound
Action :
Use a multimeter or small buzzer across the
Bell +&- terminals to determine if the control
panel is triggering the bell. If all is O.K check
the operation of the sounder by wiring it to the
system battery.
On 27/05/2020 at 21:52, Sideshow said:
Bell test works and system sets okay
Another house maybe? Or you meant internal bell
Yes the external Bell test worked, but the original fault is still apparent that if the system is triggered the external alarm does not sound.
  • datadiffusion changed the title to Eurosec Alarm System - siren / wiring issues
To do the Bell Test i entered the User code and pressed 9, as per the Eurosec User manual page 19.
The bell test worked.
Not sure what else it could be? is it worth resetting the whole system if this is possible?
