Hi all,
I am after a little bit of advice regarding my home alarm.  I have a Honeywell ADE Gen4 alarm panel and Honeywell Viper Sensors on my windows.  One fo the sensors took a bit of a whack during some house work and, as a result, the house alarm went off.  I entered my code to silence but now both the Tamper and Day LEDs are lit and the keypad is unresponsive.  I try to enter my code to reset the system but nothing happens.
Has anyone any suggestions on how I can reset the alarm so I can set it again?
Thanks
Rob.
Thanks for the reply.
Once I've had a look at the sensor, would I need to use an engineer to unlock the alarm or is it something I could do myself?
I'm by no means an expert but I have changed a few sensors on an alarm in the past.
Thanks, Rob.
Thanks, Rob.
Expand
Press the "×" button
Hi all,
Thanks for the advice.  Managed to look at it today.  Not sure what had happened but I just gave the Viper Sensor on the window a tap and it went out of the tamper mode and all is well again.
Thanks again
Rob
  On 28/05/2020 at 18:09, Rob H said:
Hi all,
Thanks again
Rob
Expand
Lol
Hi all,
Thanks again
Rob
Expand
I wouldnt want to rely on that 'repair'
Expand
Well when it comes to cars  hitting the engine with a hammer might temporarily fix the problem
