10 hours ago, sixwheeledbeast said:
You said that you can't clear down if it calls a landline, I would be starting to diagnose from there to make sure that is correct.
I have known some devices not to sent DTMF while in a call, you have to go to another menu or need some third party app to enable this.
If it requires an app this may have it's own controls in settings or require your volume to be higher, will difffer from device to device.
Making sure landline to landline (or even the old Iphone) works first would rule out a fault elsewhere.
They said it works on the old iphone?
Yes only works on the old iPhone 6. PeterJames, when you say "they" who are you referring too? Does this mean I have to upgrade the dialler so I works with our samsung S9 mobiles?
It's a great cheap feature to have on system, especially when we are away.
I was replying to SWB, (Which is why I quoted him) I meant that you had said in your original post that it worked on your old iphone.
I was replying to this statement in particular
What happens when you switch the phone quickly to speaker phone and then press * (once after each beep )
4 minutes ago, Sdgservices said:
It won't reset dialler with speaker on or off, we've tried both ways ?
To much hassle
Get new alarm system with an app or new phone
Done deal , fanito , khalaas , done
Or get a dog as Mr H says
9 hours ago, james.wilson said:
On a serious note I assumed diallers would be immune from IP core changes, it appears they may not be
But these diallers have this issue
Sometimes networks does this , seen it many times , your pressing the button but it's not stopping and them suddenly it will work
