Tanny Posted June 12, 2020 Posted June 12, 2020 My alarms gone off as my electricity was cut I cant remember the process to turn it off I do no my pass number. Quote
Tanny Posted June 12, 2020 Author Posted June 12, 2020 On 16/08/2003 at 07:52, Guest ceemgee said: I wonder whether anyone has a manual for a SL Compact alarm system, which was installed in my house when I moved in? I am unable to find it on the Net, as I don't know what SL stands for. Help! Thanks. Quote
Tanny Posted June 12, 2020 Author Posted June 12, 2020 3 hours ago, Tanny said: My alarms gone off as my electricity was cut I cant remember the process to turn it off I do no my pass number. I could do with a manual if anyone has one 3 hours ago, Tanny said: My alarms gone off as my electricity was cut I cant remember the process to turn it off I do no my pass number. Quote
al-yeti Posted June 12, 2020 Posted June 12, 2020 2 minutes ago, Tanny said: I could do with a manual if anyone has one Start another topic? Model make of alarm etc Quote
Tanny Posted June 12, 2020 Author Posted June 12, 2020 10 minutes ago, al-yeti said: Start another topic? Model make of alarm etc sl compact Quote
Tanny Posted June 12, 2020 Author Posted June 12, 2020 3 hours ago, Tanny said: My alarms gone off as my electricity was cut I cant remember the process to turn it off I do no my pass number. its an sl compact alarm Quote
sixwheeledbeast Posted June 12, 2020 Posted June 12, 2020 Alarms that activate like this during a power cut are most likely unmaintained and will require servicing by an engineer. We do not provide engineering manuals, defaulting procedures, codes or disabling information here. I can only suggest that you try all the user codes you can think of and if the alarm will not silence you will have to contact someone to repair it. It's recommended you service your system regularly, (even if you don't arm it often) so this type of thing doesn't happen. 1 Quote
datadiffusion Posted June 12, 2020 Posted June 12, 2020 (edited) 40 minutes ago, al-yeti said: Start another topic? Please don't start another topic. As above we do not give out enongeering manuals and it's likely you'll need an engineer. Edited June 12, 2020 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
sixwheeledbeast Posted June 12, 2020 Posted June 12, 2020 Al was right, I already split all this out but I was busy at the time so didn't fix the title or post. Quote
al-yeti Posted June 12, 2020 Posted June 12, 2020 3 minutes ago, datadiffusion said: Please don't start another topic. As above we do not give out enongeering manuals and it's likely you'll need an engineer. I think we should start on you Quote
