garnayrob Posted June 13, 2020 Posted June 13, 2020 Hi, Appealing to the Texecom experts for some guidance! I have a Texecom Premier Elite and want to Part Set my alarm for when the dog is home and we go out. I’ve configured Part Set 2 to omit 2 PIRs in the space the dog occupies, however what I can’t get my head around is how I enable the front door contact (Zone 9) to act as an Entry / Exit rather than being armed. I want to be able to set alarm as Part Set 2 and exit through the front door contact (Zone 9) as I would when setting the alarm normally. Likewise I want to be able to enter and disarm as normal. How do I achieve this? Quote
sixwheeledbeast Posted June 13, 2020 Posted June 13, 2020 A zone programmed as E/E would be E/E for all part arms as default. My guess would be you either have enabled the Guard on Part attribute for Zone 9 or you have Part arm on Instant? Quote
garnayrob Posted June 13, 2020 Author Posted June 13, 2020 2 hours ago, sixwheeledbeast said: A zone programmed as E/E would be E/E for all part arms as default. My guess would be you either have enabled the Guard on Part attribute for Zone 9 or you have Part arm on Instant? Hi thanks for your reply. I’ve not actually changed anything on Front Door Zone 9 yet so it can probably stay set as is then, cheers Quote
garnayrob Posted June 20, 2020 Author Posted June 20, 2020 Hi all, just in case anyone else trying to do this, I ended up doing the following: Omitting the two zones (setting to off) for Part Set 2 (which I renamed text to “Dog at Home). No change needed to front door contact (zone 9) - this behaves the same way by default allowing you to exit and enter / counting down. I also allowed the Part Arm to exit tones in the Area Options by clearing out “AB” areas from Part Arm Silent. Had to test it all with family roaming the house, made easy with a few bits of tin foil over the active PIRs Quote
james.wilson Posted June 20, 2020 Posted June 20, 2020 Thanks for the follow up Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
PeterJames Posted June 20, 2020 Posted June 20, 2020 34 minutes ago, garnayrob said: a few bits of tin foil over the active PIRs dont forget to remove the foil now Quote
garnayrob Posted June 21, 2020 Author Posted June 21, 2020 9 hours ago, PeterJames said: dont forget to remove the foil now Quote
