Yassine Posted July 4, 2020 Posted July 4, 2020 Hi All, I did read many post on the forum before starting this one so please excuse me im repeating someone else question. Im linking Siren Texecom Odyssey E1 With Wolfguard GSM Alarm I don't know if they work properly Could someone tell me if it's possible to pair this siren with this control panel and what links I have to follow Any help would be appreciated. Quote
al-yeti Posted July 4, 2020 Posted July 4, 2020 58 minutes ago, Yassine said: Hi All, I did read many post on the forum before starting this one so please excuse me im repeating someone else question. Im linking Siren Texecom Odyssey E1 With Wolfguard GSM Alarm I don't know if they work properly Could someone tell me if it's possible to pair this siren with this control panel and what links I have to follow Any help would be appreciated. Unlikely anyone uses that alarm Anymore pictures or a link to the installation manual ? Quote
PeterJames Posted July 4, 2020 Posted July 4, 2020 Never heard of a wolfguard doesnt look like it has a tamper return, the bell needs a negative trigger that I would guess you can get from N/O on the panel; and adding OV to common Quote
al-yeti Posted July 4, 2020 Posted July 4, 2020 Assuming that zone on the back is programmable it might work , you also have an onboard relay which could be used for a bell trigger depends on what it does Quote
Yassine Posted July 4, 2020 Author Posted July 4, 2020 35 minutes ago, al-yeti said: Unlikely anyone uses that alarm Anymore pictures or a link to the installation manual ? The Manual of Odyssey 1Ehttp://www.moretonalarms.com/pdf_engineer_manuals/Odyssey.pdf The Manual of Wolfguard GSM Alarm (this is different model but almost the wired zone are the same) http://www.wolf-guard.com/app/file/8 57 minutes ago, PeterJames said: Never heard of a wolfguard doesnt look like it has a tamper return, the bell needs a negative trigger that I would guess you can get from N/O on the panel; and adding OV to common I tried but nothing happened except the light of the siren is green Quote
PeterJames Posted July 4, 2020 Posted July 4, 2020 1 minute ago, Yassine said: I tried but nothing happened except the light of the siren is green The siren need permanent 12v Quote
Yassine Posted July 4, 2020 Author Posted July 4, 2020 1 minute ago, PeterJames said: The siren need permanent 12v Do you mean 12v from control panel is insufficient ? because Last year I linked with wired siren from different brand with 12 v from control panel of this gsm alarm and it is working great but with Odyssey 1E I don't know how or where I am wrong Quote
PeterJames Posted July 4, 2020 Posted July 4, 2020 I would guess, 12v and GND on CPU to 12v and 0v on bell, put a link from GND on CPU to COM then wire N/O to B on Bell 1 Quote
al-yeti Posted July 4, 2020 Posted July 4, 2020 50 minutes ago, Yassine said: The Manual of Odyssey 1Ehttp://www.moretonalarms.com/pdf_engineer_manuals/Odyssey.pdf The Manual of Wolfguard GSM Alarm (this is different model but almost the wired zone are the same) http://www.wolf-guard.com/app/file/8 I tried but nothing happened except the light of the siren is green Seems as though you can't programme as above So you need to use 0v +12v Then the relay for the bell trigger , which drops bell trigger to 0v when siren goes The tamper could be used on a zone in defence mode , look at page 11 , although not a tamper it can act as a 24hr armed zone , but you would have to mess around to make it work Quote
james.wilson Posted July 4, 2020 Posted July 4, 2020 1 hour ago, Yassine said: Do you mean 12v from control panel is insufficient ? because Last year I linked with wired siren from different brand with 12 v from control panel of this gsm alarm and it is working great but with Odyssey 1E I don't know how or where I am wrong working great vs how things should work are completely different. What you mean is you thought it worked but in reality it didnt worst case you thought it did and relied on it and it didnt please all that read this use a system but know its limits, if you need to know stuff dont use a free one Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
