Hi All,
I did read many post on the forum before starting this one so please excuse me im repeating someone else question.
Im linking Siren Texecom Odyssey E1 With Wolfguard GSM Alarm
I don't know if they work properly
Could someone tell me if it's possible to pair this siren with this control panel  and what links I have to follow
Any help would be appreciated.
58 minutes ago, Yassine said:
Hi All,
Unlikely anyone uses that alarm
Anymore pictures or a link to the installation manual ?
Never heard of a wolfguard doesnt look like it has a tamper return, the bell needs a negative trigger that I would guess you can get from N/O on the panel; and adding OV to common
Assuming that zone on the back is programmable it might work , you also have an onboard relay which could be used for a bell trigger depends on what it does
The Manual of Odyssey 1E
http://www.moretonalarms.com/pdf_engineer_manuals/Odyssey.pdf
The Manual of Wolfguard GSM Alarm (this is different model but almost the wired zone are the same)
http://www.wolf-guard.com/app/file/8
I tried but nothing happened except the light of the siren is green
The siren need permanent 12v
Do you mean 12v from control panel is insufficient ?
because Last year I linked with wired siren from different brand with 12 v from control panel of this gsm alarm and it is working great
but with
Odyssey 1E I don't know how or where I am wrong
I would guess, 12v and GND on CPU to 12v and 0v on bell, put a link from GND on CPU to COM then  wire N/O to B on Bell
  • Like 1
Seems as though you can't programme as above
So you need to use
0v
+12v
Then the relay for the bell trigger , which drops bell trigger to 0v when siren goes
The tamper could be used on a zone in defence mode , look at page 11 , although not a tamper it can act as a 24hr armed zone , but you would have to mess around to make it work
but with
working great vs how things should work are completely different.
What you mean is you thought it worked but in reality it didnt
worst case you thought it did and relied on it and it didnt
please all that read this use a system but know its limits, if you need to know stuff dont use a free one
