Yassine Posted July 5, 2020 Author Share Posted July 5, 2020 14 hours ago, al-yeti said: Seems as though you can't programme as above So you need to use 0v +12v Then the relay for the bell trigger , which drops bell trigger to 0v when siren goes The tamper could be used on a zone in defence mode , look at page 11 , although not a tamper it can act as a 24hr armed zone , but you would have to mess around to make it work I'm lost in the linking The control panel wired ports: *) NO - Relay port (normal open). It will be triggered when the system is alarming. *) COM - GND port of relay *) NC - Relay port (normal close). It will be triggered when the system is alarming. *) 12V - Positive end of 12V output *) Zone2 - Wired sensor 2: support both NO and NC *) GND - GND *) Zone 1 - Wired sensor 1: support both NO and NC *) GND - GND *) There is audio jack for siren S+ S- Siren Control panel 12v ----------------------------> 12V 0V ------------------------------> GND Bell ----------------------------> ? STRB ------------------------> ? what I have to link for bell and STRB ? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted July 5, 2020 Share Posted July 5, 2020 17 minutes ago, Yassine said: I'm lost in the linking The control panel wired ports: *) NO - Relay port (normal open). It will be triggered when the system is alarming. *) COM - GND port of relay *) NC - Relay port (normal close). It will be triggered when the system is alarming. *) 12V - Positive end of 12V output *) Zone2 - Wired sensor 2: support both NO and NC *) GND - GND *) Zone 1 - Wired sensor 1: support both NO and NC *) GND - GND *) There is audio jack for siren S+ S- Siren Control panel 12v ----------------------------> 12V 0V ------------------------------> GND Bell ----------------------------> ? STRB ------------------------> ? what I have to link for bell and STRB ? Bell and strobe would be tied together into the normally open side of the relay , then common relay to 0v , I think lol The tamper you need to for now ground it in the bell if it allows so it ignores it , I think lol Quote Link to comment Share on other sites More sharing options...
PeterJames Posted July 5, 2020 Share Posted July 5, 2020 Common on the control panel (CPU) links to ground Quote Link to comment Share on other sites More sharing options...
Yassine Posted July 5, 2020 Author Share Posted July 5, 2020 2 hours ago, al-yeti said: Bell and strobe would be tied together into the normally open side of the relay , then common relay to 0v , I think lol The tamper you need to for now ground it in the bell if it allows so it ignores it , I think lol 1 hour ago, PeterJames said: Common on the control panel (CPU) links to ground I don't need TMP for now I linked Siren Control panel 12v ----------------------------> 12V 0V ------------------------------> GND AND COM Bell ----------------------------> NO STRB ------------------------> NO Nothing happened am I wrong in the linking ? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted July 5, 2020 Share Posted July 5, 2020 Maybe the panel relay is knackered or the bell its hard to say without looking if yo move the wire frome N/O to common does the bell sound? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted July 5, 2020 Share Posted July 5, 2020 57 minutes ago, Yassine said: I don't need TMP for now I linked Siren Control panel 12v ----------------------------> 12V 0V ------------------------------> GND AND COM Bell ----------------------------> NO STRB ------------------------> NO Nothing happened am I wrong in the linking ? Nothing happens when you do what? Quote Link to comment Share on other sites More sharing options...
Yassine Posted July 5, 2020 Author Share Posted July 5, 2020 4 hours ago, PeterJames said: Maybe the panel relay is knackered or the bell its hard to say without looking if yo move the wire frome N/O to common does the bell sound? Nothing happened 3 hours ago, al-yeti said: Nothing happens when you do what? when I triger the siren from control panel or when PIR triger I think I have to use the Siren+ and siren- I tried Siren Control panel 12v ----------------------------> 12V 0V ------------------------------> GND AND COM Bell ----------------------------> NO STRB ------------------------> NO ANd Siren Control panel 12v ----------------------------> 12V 0V ------------------------------> GND AND COM Bell ----------------------------> COM STRB ------------------------> COM Quote Link to comment Share on other sites More sharing options...
PeterJames Posted July 5, 2020 Share Posted July 5, 2020 12 minutes ago, Yassine said: Nothing happened Siren Control panel 12v ----------------------------> 12V 0V ------------------------------> GND AND COM Bell ----------------------------> NO STRB ------------------------> NO Either the sounder doesnt work, or the panel isint outputting 12v. If you have wired 12v and gnd and the wired bell to gnd it should have sounded Quote Link to comment Share on other sites More sharing options...
al-yeti Posted July 5, 2020 Share Posted July 5, 2020 11 minutes ago, PeterJames said: Either the sounder doesnt work, or the panel isint outputting 12v. If you have wired 12v and gnd and the wired bell to gnd it should have sounded That's the first move to try make sure your bell is working But wouldn't the bell wait for the tamper to close and he's forgetting that? Quote Link to comment Share on other sites More sharing options...
Yassine Posted July 5, 2020 Author Share Posted July 5, 2020 15 minutes ago, PeterJames said: Either the sounder doesnt work, or the panel isint outputting 12v. If you have wired 12v and gnd and the wired bell to gnd it should have sounded I'm trying now with Power Supply 12V DC 12v ----------------------------> 12V+ 0V ------------------------------> - and from control panel I wired Siren Control panel Bell ----------------------------> GND STRB ------------------------> GND nothing happened when I trigger the siren from control panel or PIR trigger Quote Link to comment Share on other sites More sharing options...
