Honeywell Galaxy understand model naming
15 hours ago, al-yeti said:
That's what I thought
C for confused dot come in my case lol
They both have Comms on board tho
The early pre dimension could be bought with or with comms onboard C for comms and as GG stated they didnt have any rear off wall tamper. Well that how we always order them.
  • Upvote 1
www.nova-security.co.uk
www.nsiapproved.co.uk
Link to comment
Share on other sites
Ok dude I remember the external coms devices and cards
Link to comment
Just to note that the panel you're looking at on eBay is cheap for a reason. It's not new and looks like it has been a swap out.  That is, the installer has a fault on an installed system and they then switch out the PCB.  If you look at the PCB, you can see that the screw terminals have been used.  The PCB serial number doesn't match the box serial number and that's a classic sign of this type of swap out. I suspect that this panel will not boot, so if you do buy, don't put it on the wall without thoroughly testing it. I've had quite a  few people who have bought these returns - some are lucky and some not so. I think the seller is pretty decent though. He'll refund on return.  It's a bit of a hassle for the saving against buying the V7.03 CO48-D-E1 though! Especially the ones that come with Ethernet modules ?
  • Thanks 1
Link to comment
9 hours ago, GalaxyGuy said:
Just to note that the panel you're looking...
Thanks for the interesting review on that, I will keep this in mind.
My initial idea is to set up the system to play with, to see how 'difficult' is to be a security engineer. Hopefully, any system will be just fine for that?
Link to comment
Also, this is the main reason why it must be as cheap as possible.
Link to comment
coloured wires & basic DIY skills, shave a monkey & kick it though a branch of screwfix,
if its holding a multi meter & screwdriver on the way out.... vola you have have an alarm monkey
however if you can take a current reading your over qualified ?
The easy way to find out if your suitable for a job is to go & get one, if you can't do it or don't like find a different one
  • Thanks 1
  • Upvote 1
Link to comment
Nah, this means you can probably fault find , so qualified.....
Link to comment
do you have a fear of heights ?
why not get a job in an industry which put little plastic boxes up using triple ladders....
Link to comment
I do a bit , hate the bell boxes high up never understood why they do that , bunch of nuttas and muppets
Link to comment
