ipaq 2210
Security Technician
I haven't done it with bluetooth but it's pretty straightforward with IrDA
32803[/snapback]
Worth a shot, even for the interim until bluetooth decides to work.
The other way, which I think will work better than either of the above, is a data cable between the iPAQ and the phone.
Nokia do a guide for setting up an Ipaq with a 6301i Here this might point you more in the right direction.
If you want to use the GPRS connection then this may also help
Colin.
