NCLeeds Posted July 21, 2020 Posted July 21, 2020 The RCD in our fuse box tripped, not due to the alarm, but switching off the alarm circuit in the process. When I sorted the RCD, the alarm box was beeping so in the end I just turned off the circuit and we went without an alarm for a while. I'm now getting around to sorting it. I've replaced the battery and it seems to work as expected when setting: enter code, press FULL, hear the usual beeps. But it doesn't stop beeping when I enter the code again. It only stops when I enter the engineer code, or when I press RESET. I've reached the end of my knowledge (not hard!) on this. Any ideas? Quote
sixwheeledbeast Posted July 21, 2020 Posted July 21, 2020 You have the engineers and user codes the wrong way round I'd guess. 1 Quote
FASTCAR Posted July 21, 2020 Posted July 21, 2020 If it stops beeping when you press RESET , then it hasn't set , are there any leds lit?. Either way it has defaulted and requires reprogamming to suit your requirements. Quote
