Posted (edited)
Had to remove an old sounder, but several wires had been routed through the box, one wire was accidentally cut during the removal and the keypad next to it went blank and the alarm sounded.....put it into engineer mode & had the wire repaired....however now when trying to set the alarm it says  CONFIRM DEVICES can I clear this using engineer mode ?
many thanks
Edited by Reddwarf4ever
You have lost some network devices, you will have to confirm them again in said menu.
If you don't know why they are missing don't just confirm it because you may disable whatever modules and therefore detection that are missing.
many thanks
Maybe the wire cut also feeds an expanded somewhere and you have repaired all the pairs? Only ones that went to keypad?
