al-yeti Posted July 26, 2020 Posted July 26, 2020 I guess I could type it out but I am going to be lazy , your just getting confused the word eol , ignore it , so then instructions are the same as what I said before White and green to tamper terminals Blue and yellow to alarm terminals Black is minus - terminal Red is positive + terminal Quote
scotslad469 Posted July 26, 2020 Author Posted July 26, 2020 19 minutes ago, al-yeti said: I guess I could type it out but I am going to be lazy , your just getting confused the word eol , ignore it , so then instructions are the same as what I said before White and green to tamper terminals Blue and yellow to alarm terminals Black is minus - terminal Red is positive + terminal Thanks for the help. I owe you a few of these Quote
al-yeti Posted July 26, 2020 Posted July 26, 2020 26 minutes ago, scotslad469 said: Thanks for the help. I owe you a few of these Iron brew? Quote
MrHappy Posted July 27, 2020 Posted July 27, 2020 10 hours ago, al-yeti said: Iron brew? 5 cups of cold piss ? Quote Mr Veritas God
scotslad469 Posted July 27, 2020 Author Posted July 27, 2020 Iron brew for the hangover. But beer to cause that effect Quote
MrHappy Posted July 27, 2020 Posted July 27, 2020 I once did a job in Ardrossan..... I believe the foreign office, issue the same advice to travelers as they do for mogadishu, apart from the sun screen ? 1 Quote Mr Veritas God
al-yeti Posted July 27, 2020 Posted July 27, 2020 5 minutes ago, MrHappy said: I once did a job in Ardrossan..... I believe the foreign office, issue the same advice to travelers as they do for mogadishu, apart from the sun screen ? Mogadishu is safer to travel to than ardossan 1 Quote
scotslad469 Posted July 27, 2020 Author Posted July 27, 2020 3 minutes ago, al-yeti said: Mogadishu is safer to travel to than ardossan You would be required to wear a Haz mat suit at all times and that was before COVID-19 1 Quote
norman Posted July 27, 2020 Posted July 27, 2020 lol Quote Nothing is foolproof to a sufficiently talented fool.
scotslad469 Posted July 28, 2020 Author Posted July 28, 2020 (edited) Thanks to all the replies. PIR now working perfectly few issues I forgot I set the alarm to all the defaults so not knowing the default pin was #### i triggered the tamper and couldn’t shut it down but got it all done in the end. Edited July 28, 2020 by sixwheeledbeast no codes please Quote
