I guess I could type it out but I am going to  be lazy , your just getting confused the word eol , ignore it , so then instructions are the same as what I said before
White and green to tamper terminals
Blue and yellow to alarm terminals
Black is minus - terminal
Red is positive + terminal
Thanks for the help. I owe you a few of these ?????
Iron brew?
I once did a job in Ardrossan.....
I believe the foreign office, issue the same advice to travelers as they do for mogadishu, apart from the sun screen ?
  • Like 1
Mogadishu is safer to travel to than ardossan
  • Like 1
You would be required to wear a Haz mat suit at all times and that was before COVID-19
  • Like 1
Posted (edited)
Thanks to all the replies.
PIR now working perfectly few issues I forgot I set the alarm to all the defaults so not knowing the default pin was #### i triggered the tamper and couldn’t shut it down but got it all done in the end.
Edited by sixwheeledbeast
no codes please
