46 minutes ago, sixwheeledbeast said:
Nope, use the Texecom Impaq ones unless I have to use proper Vipers for replacement (aesthetics/latch line etc)
Mostly wireless shocks now if customer needs perimeter.
They havent been triggered in a very long time maybe since they have been installed. Alarm will set and unset as normal and will trigger if they are bashed or knocked.
Yes wireless shocks work better don't you think aswell?
1 hour ago, james.wilson said:
the viper will flash like that its a 'comfort' led if you tap them again the led will stop for about 7 sec. Best to have them in this mode its like comfort leds on a bell, shows its powered
Can the led’s be turned off ?
