Volume control galaxy MK7 keypad
Guest aviator
Guest aviator
I need the keypad code for adjusting the volume of MK7 buzzer.
Please help.
Please help.
32826[/snapback]
Connected to which panel?
(gal 8/16 can be done, the others can only be on or off, and that is an engineer function)
32853[/snapback]
Manuals not with me, but i'm sure its on the ademco website
for the 8/16 you press the star key and another key
this will do vol/backlight/print log
It is not keys 8/5/2 though
*1 keypad buzzer volume
*2 PA
*4 keypad lighting on\off
Guest aviator
I am sorry, to be incomplete.
It's a 60 panel mod V4. I know the ON/OFF function is in the service menu (58), always was.
But I believe that the more recent panels and keyboard has a volume controle via the keypad aswell
32861[/snapback]
Nothing on my keypad
If the vol is a problem may be you could fit an extension speaker, which you
would then have full control over the volume?
  • 1 month later...
Resistors in line in the speaker but it mutes all tones.
Added for not reading post properly...
blu tak twisted to a fine conical shape and pressing lightly in the actual piezo through the opeing.
